the pics arent great but can anyone tell me if these domes look like they were cleaned up or modded for a 4mill? from the edge to the center where it dips down it seems too flat to not be modded and theres little rings around it like they were machined
My link
http://i996.photobucket.com/albums/af82/victorkijonka/dome2.jpg
i cant really see it but it looks like that dome si for blaster pistons. looks like they dip in pretty sharpe. i maybe wrong but someone may chime in
if it turns out they are for a blaster can I use them if the compression is where I want is the other question?
when i bought my bike it had 18cc blaster domes in and i dont have blaster pistons and it ran awesome. but is is right or wrong i dont know. i dont wanna tell you yes and then your engine blows up abd you blame so other will chime in i am sure.
dome appears to be modded. that's not how they are right from pro-design.
I know thats why Im hoping someone knows. I thought it might of been to clean it up but only the outside was changed and the middleshave no damage
I have a set of 19cc domes sitting right next to me and they are cut deeper. After the face O-ring they are slated prob at a 30deg angle im guessing.
do you run them with normal pistons and stock stroke?
the squish band ain't at no 30deg angle. and neither is the "bell" of the dome. that is cut at a radius. it's a hemispherical dome.
