chevybanshee350 Posted July 12, 2010 Report Posted July 12, 2010 I have a 2004 banshee, it has a 4 mill crank, mx ported cylinders by Herr Jugs , Dmc pipes,air box lid removed, stock carbs with 340 mains, Needles on middle clip, and 27.5 pilots, air screws 1 1/2 out. The problem is when you are riding on the trails, and holding the throttle steady at 1/8 to 1/4 throttle then go to floor it, it bogs real bad, then takes off. I tryed the air screw everywhere and nothing helps. Should i try the needles. ANY HELP IS APPRECIATED Quote
SAVAGE420 Posted July 13, 2010 Report Posted July 13, 2010 Has it always done this, happen outa the blue one day? If it was me, i would play with the clip and raise it on the needles now that it's hot out to lean it out a tad in the mid range. Put your air screws back where they were. Have a try and check back. Quote
chevybanshee350 Posted July 13, 2010 Author Report Posted July 13, 2010 Seems to just have started to do this lately. Also when you pull the air filter off there seems to be alot of fuel laying in there. I Dont know its driving me crazy. I will mess with it tomorrow after work. Quote
SAVAGE420 Posted July 13, 2010 Report Posted July 13, 2010 100% sure its fuel in the box? What filter do you use? Quote
chevybanshee350 Posted July 13, 2010 Author Report Posted July 13, 2010 Its Not in the air box just the tubes that go from the air box to the carbs. It has a K&N on it Quote
