MKIII_96 Posted July 5, 2010 Report Posted July 5, 2010 ok i was lookin at everyones mods and jetting and there numbers seem alot higher than mine. i have fmf fattys and silencers, reeds, reed spacers, KN filter, wiseco pistons bored .80 over, shaved head, slight port work on exhaust and my jetting is 25 pilots and 260 mains. im at sea level. does this sound right? the bike runs good and starts up first kick every time. Quote
toomuchhorrorbusiness Posted July 5, 2010 Report Posted July 5, 2010 (edited) Sounds a little lean in my opinion. Are you familiar with reading plugs? Search plug chop That's the only way to know for sure. You drive a mk3 VW I'm assuming? Where you from? Edited July 5, 2010 by toomuchhorrorbusiness Quote
GrMeyer Posted July 6, 2010 Report Posted July 6, 2010 Here are my ?'s Why are you running a reed/carb spacer? Are you running stock carbs? Do they have the TORS removed? What intake filter set up are you running?(Pods, Air box with no lid, Air box with lid. Air box lid with holes cut or drilled in it? Im going so say that the 25 pilots are going to be cutting it short when winter comes if your not running the lid. As for the mains. We need to know the intake set up. Quote
