I just installed the Vito's T.O.R.S eleminator throttle cable and the fuck gets stuck some times. What up with that? :unsure:
make sure the carb slides and bores are clean and no burrs after drilling the idle screws, check cable routing
Thanks, I looks and feels clean. I'll try to rerout the cable. It shore is one hell of a ride when it sticks. banghead Do you have the veto's cable?
mine has stuck when slides get wet or dirt in them
Thanks guys. I'm going to pull the carbs and clean them. Hope this works. :notworthy:
yes I do ,never had a problem though, just in case I use a tether kill switch with a short lanyard
also make sure the slides are in the correct carbs, look at the sync windows
Edited by toytech
Slides are in the right carbs. Found some trash though, Plus carbon on one like my reeds are bad.
