Brandon,
You're not doing anything for the Cheetahs above 68mm bore though, right?
D, we are testing a 72mm but that gets the sealing surface pretty thin. No thinner than an oring I guess but I like to maintain our design minimums of 5% of bore for mating surface area. I suspect the 72mm will work if everything is assembled to perfection but the testing will have to prove that to us. I guess if the demand was there, we could design a fire ring system into the 72mm to ensure proper seal but that will drive price up a bit. 72mm would be absolute max for that head though. 68mm has been proven very reliable for us running the 573 series pistons.
Your modding the stock heads to fit a 73mm bore?
No, we are still doing testing on a 72mm but that is as far as I would feel comfortable doing. Just not leaving enough sealing surface after that. We have done plenty of the 68mm without issue. A lot of guys running the 4mil, 7mil, and 10mil with 68mm bore and we have plenty of those setup right now.
sorry brandon.. I posted and realized the same question was asked and already answered.. so I delted my post.
Brandon, are you machining stock banshee heads to fit cheetah cylinders or cub cylinders? I was under the impression that the cheetah heads were totally different the the banshee heads (bolt pattern, cylinder spread, etc.)
I probably mislead somewhere in my posts. Stock heads modded for Cheetah cubs are what we have been doing. 4mil-14mil. We are now working on a super cub head at 72mm bore. Other castings will require a different head design. We also do many mods for stock cylinder configurations like the ever popular 4mil LR.
That's what I wanted to know B.
I read stock head and Cheetah...and aside from the bore, the studs are located differently...so I was wondering what you had up your sleeve for that.
I'm with you now...I gotcha!
Yeah, I probably misread the thread here and had "cub" on my mind.
