I just put some 34MMpj on a 421 setup and it runs good up top but boggs really bad on take off.
pilots 58
main .108
needle on first clip......
dump tube .122
i had the main at .120 and the bog was worst....also where should the choke knobs be set at because it seem to rev better when i turn them out.
sealevel
vito's HIGHFLOW powerjets......and they dump alot of fuel!!!
180psi
+10 timing
CPI's O/F
Will the pilotjet cause a bad bog if its to big?
its not a lean bog because its hard to clear it out.
