killed300ex Posted June 9, 2010 Report Posted June 9, 2010 Looking to sell my 97 banshee motor is fresh 200 lbs of compression last time I checked. Barley been used since the rebuild, new 4 mill long rod stroker crank, LA sleeve BB top end on a stock bore. delta v force reeds pwk 38mm carbs. Lockup clutch and side cover. Has a 4 speed override in it with new shift forks on rebuild been run about 1/2 hour since. Would be willing to pull the motor and swap in a regular trans for no cost if youd rather that. All motor work has been done at a local reputable builder (LD&R machine in North Berwick ME) You are more than welcome to call and talk to him and he will confirm and can tell in detail what has been done to the motor. It runs very strong for a LA sleeve motor. This was one of his personal drag motors for a couple years before I got it so you know it was built right. I am including 2 sets of asphalt tires one on carbon fiber rims. (One is a hard compound one a soft) Also a set of maxis 4 snows that I used for pit riding and the sand drags. Comes with a wheelie bar. Is lowered so the frame sits 4" off the ground. I do have all the factory suspension that will go with the bike and I am willing to install if thats what you want it setup for. It has out of frame drag pipes on it. This bike has everything needed to be a decent drag bike or trail bike with the parts I am including all it would need is a set of inframe pipes for trail riding. Looking for 2500 OBO Located in Rochester NH Best way to contact me is at my email [email protected] as I can get it right on my phone Quote
