MIKE_XT Posted June 6, 2010 Report Posted June 6, 2010 Hi guys, I've recently done a few suspension mods to the banshee, but now my front end is wider than the rear (+2+1 LT Laeger A-Arms & Lonestar Axcalibar Axle). But I've come to the conclusion that my axle must be at the thinnest setting (adjustable +1" to +3.5" from memory). My question is how do I adjust it? I've looked around the axle and can't see anything. Any help would be greatly appreciated!! Cheers, Mike Quote
donkeypuncher Posted June 6, 2010 Report Posted June 6, 2010 Hi guys, I've recently done a few suspension mods to the banshee, but now my front end is wider than the rear (+2+1 LT Laeger A-Arms & Lonestar Axcalibar Axle). But I've come to the conclusion that my axle must be at the thinnest setting (adjustable +1" to +3.5" from memory). My question is how do I adjust it? I've looked around the axle and can't see anything. Any help would be greatly appreciated!! Cheers, Mike there should be 3 small shims/spacers on each side of the axle (near wheel hub). to make the axle wider the shims need to be on the inside of the wheel hub. Quote
MIKE_XT Posted June 7, 2010 Author Report Posted June 7, 2010 Thanks for your help mate. I don't keep the bike at home, so I'll have to have a look in the next week or so and try and adjust it out. If the axle is on the thinner setting where will the shims be? Does anyone have a photo? Quote
MIKE_XT Posted June 7, 2010 Author Report Posted June 7, 2010 Actually, now that I've taken a second to think about it, I reckon I have it sussed. Thanks a lot for your help!! Quote
