This sucks but I have to part out my project before its finished due to some unforseen circumstances. Everything is still pretty much new unless otherwise noted. I will have prices here soon and pictures. I will combine items to make shipping as cheap as possible. I wil not part out the motor. I would like to see the motor and frame go first. Parts and bike are for sale localy in Omaha,Ne.
421 ported cub cylinders with blaster pistons, Hotrods crank with tz and max load bearings, 1-5 override trans, Adjustable timming plate with stock stator, lockout clutch, V-force 3 reeds and billet intake for 35-39mm carbs. Cylinder and cases were ported by Dirt Works in Grand Island, Ne. Everyting is new except cases. Has chrome cover on stator side and chrome lock out cover with clear lens.
Stock frame with chromemoly subframe.
-2 +1 a-arms with polished tierods, will come with billet dust caps and spindles. cant remember the brand, metal works I think?
39mm Mikuni pwk setup for alky.
K&N Pod filters with pre-filters. New
Stock fuel tank with dual pingle.
JJ&A 40mm Drag axle, complete minus carrier.
JJ&A 40mm axle carrier with bearings.
+10 tyson swingarm with chain.
13 paddle extremes on rims.
front marvin shaws.
rear marvin shaw.
front spindle mounts with tires.
polished rear brake caliper with braided line.
polished rear brake piston and resevoir with chrome cap.
chrome brake lever.
chrome shift lever.
chrome steering stem.
chrome motor mounts.
polished footpegs.
billet thumb throttle.
billet levers.
Drag cut seat with crushed velvet.
factory radiator with hoses.
factory un-cut harness with everything.
Pm me for pictures and I will get prices on here later tonight. thanks
motor- $2200.00
Stock frame with chromemoly subframe,not cut up but a few un-needed brackets removed. fresh powder coat. 350.00
-2 +1 a-arms with polished tierods, will come with billet dust caps and spindles. cant remember the brand, metal works (metal tech) I think? 350.00
39mm Mikuni pwk setup for alky with cable . 350.00
K&N Pod filters with pre-filters. New. 75.00
Shear Big Bore out of frames, one to each side.New 350.00
Stock fuel tank with dual pingle and chrome cap. 80.00
JJ&A 40mm Drag axle, complete minus carrier. 450.00
JJ&A 40mm axle carrier with bearings. 100.00
+10 tyson swingarm with chain. New 350.00
13 paddle extremes on rims, 22x11x8, not tripple buff. like new. 350.00
front marvin shaws. 12.5 eye to eye. 250.00
rear marvin shaw. 13.0 eye to eye. 150.00
front spindle mounts with tires. New and bad a**. 450.00
polished rear brake caliper with braided line. 100.00
polished rear brake piston and resevoir with chrome cap. 75.00
chrome brake lever.40.00
chrome shift lever.40.00
chrome steering stem. like new. 80.00
chrome motor mounts.40.00
polished footpegs. 50.00
billet thumb throttle assembly. 35.00
billet levers. 25.00
Drag cut seat with crushed velvet. New. 100.00
factory radiator with hoses. offer.
factory un-cut harness with everything. offer
you can email all the pictures to me bnasty and ill put them on here through my photobucket account if you would like. Just send them to the same email you sent the pictures of the marvins to. On the marvins, are they competition series or hillshooters? If they are comps im pretty sure you can consider them sold! let me know on that part though and get me the rest of the pics and ill be glad to help you out.
I pm'd u back. I want the arm, chain, levers and pingle valve. Shoot me a price and payment info. Thanks. Eric barbier. 985-518-5881.
Edited by eric b
Got some great prices on here, obviously as you know Pics will help...but this stuff should move.
Try going to imageshack.com and uploading pictures there as well. Free, no sign up...and you copy/paste the forum code link.
I recieved pics via email for all the items I requested.
whats the deal man.... we going to deal on those parts or what.... let me know something ..................................... thanks
