kpennepacker Posted May 27, 2010 Report Share Posted May 27, 2010 I just bought a banshee and tore it down to rebuilt and I pulled the carb off. They are Mikuni flatside carbs. The guy before me cut the stock boot so they would slide on and rtv the crab out of it.... I can't figure out what size they are to get the correct boot. The I.D of the inake side measures 34mm and the O.D measures 40mm. So what boot do I buy because they won't slide into the boots i have. Charriot racing has intakes from 26-36 or 38-40. Which should fit. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
toytech Posted May 28, 2010 Report Share Posted May 28, 2010 (edited) I just bought a banshee and tore it down to rebuilt and I pulled the carb off. They are Mikuni flatside carbs. The guy before me cut the stock boot so they would slide on and rtv the crab out of it.... I can't figure out what size they are to get the correct boot. The I.D of the inake side measures 34mm and the O.D measures 40mm. So what boot do I buy because they won't slide into the boots i have. Charriot racing has intakes from 26-36 or 38-40. Which should fit. Any help would be appreciated. the id is the size of the carb so you need boots for 34mm carbs. take a look at the Chariot or Boss billet intakes with the built in crossover not much more money than just the boots Edited May 28, 2010 by toytech Quote Link to comment Share on other sites More sharing options...
kpennepacker Posted May 28, 2010 Author Report Share Posted May 28, 2010 the id is the size of the carb so you need boots for 34mm carbs. take a look at the Chariot or Boss billet intakes with the built in crossover not much more money than just the boots Thanks. I appreciate it. Quote Link to comment Share on other sites More sharing options...
