which nub is it supposed to go on? its loose and if were talking about the same little nub it seems impossible to get it off
The hook on the spring hooks around the spring post just to the left of the kicker shaft. You will see it.
Also before you do that make sure to seat the kick start arm in the case boss. Basically put the shaft in straight with the lil "arm" on the back side sticking towards the back of the case in the lil groove.
Understand?
Understand?
ya i think so... thanks brotha
