i have 19cc domes on my cool head by pro design . pro design said if i run anything under 22cc domes i need to run race fuel? is this true? ive ran it off pump 91 and never had a problem
depends on altitude and mods... if you are really high it may be good... 21cc may be safe at sea level so...
Edited by tonyown
i'm running 21cc domes with a fresh bore and hittin about 150 psi in each cylinder. I'm running 91 no problem. I was even thinking about droppin to 20cc, but i figured i should leave well enough alone.
if your compression is over 160 psi you need race fuel.
