wideopeninpa Posted May 11, 2010 Report Posted May 11, 2010 so I am looking for a good starting point on my jetting, here is a list of mods 4 mm play port k&n filter no airbox lid 21 cc domes v force reeds toomey T-5s +4 timing The carbs are 28 mm pwks I have jjh and n86a needles. Will be running on 50/50 mix or straight av gas I haven decided yet. Elevation 800-1800 ft depending on where I am riding. So I am thinking about 50 pilot and a 158 main. What do you think? Quote
wideopeninpa Posted May 12, 2010 Author Report Posted May 12, 2010 so, nobody has any idea? I looked through the pinned link but it seems that nobody is running a simaler set up. Quote
SAVAGE420 Posted May 12, 2010 Report Posted May 12, 2010 I had sorta a similar set up as that on straight 100LL, and used 52, 155 and N68A's I liked the N68A's over the JJH's alot. Ran then on the second to top clip. Try that i bet it will be very close if not perfect. Quote
