I ride at Glamis mostly and when I run up Olds hill I run to the top in third gear. Once in a great while,on a good run, whoops aren't to deep, I can hit fourth and pull it to the top. Do you guys think I could get fourth more often with a gear change? I'm running stock gearing currently. If so what size would I go with?
drop 1 tooth in the front, you should hit powerband mid range of 4th gear on olds.. and if you are running stock now, drop 1 in the front, its cheaper then adding 3 teeth to the rear
Edited by militarybanshee
Military's 100% right. I do most of my Banshee riding in Glamis with about the same mods as you. I dropped a tooth up front and I do every dune out there in 4th. China, Olds, etc. 5th gear sometimes on a REALLY good run if the whoops aren't too bad. 11 year old all stock suspension so whoops kinda kick my butt lol.
Edited by Belal4242
