Update! Okay so, I have now done the following to my jetting...
350 mains (rich I know, just starting safe gonna work down)
27.5 Pilot
Needle 3rd clip
TORS Idle knobs 4 turns out from fully seated
Now, I HAD the air screws 2.0 turns out. BUT, if I babied the throttle in about 1mm (about 1/8th throttle or a little less) I had a slight bog engine would slow down and go whump whump. So, I turned the Air screws all the way and that seemed to clear up the bog. So my first question is, should I go up to a 30 pilot? This bike isn't all that heavily modded
My 2nd question is, with my current jetting, if I'm sitting in neutral idling and I rev it up as it comes back down I hear a a couple VERY distinct pops coming from the front of the bike. (The cylinder itself or the pipe I can't tell) it's not coming from the silencer. Is this just normal 2-strokeness or am I detonating or something? I have it jetted fairly rich at the higher throttle position, shouldn't be lean at ALL. I'm leaving for Glamis this Friday and I wanna make sure this thing doesn't blow up on me.
Thanks guys! Hope you're having good weeks.
Sean
