lookin at buying a pair of Direct Drive spindle mounts for my banshee that came off a yfz450. I was wondering if they will fil. I'm pretty sure the spindles are the same but would like your imput....thanks.
10x2 or 10x4 wheels? Stock or aftermarket spindles? I have 10x2's that i can try on a stock spindle for ya. I'm pretty shure you can make them work but would like to make sure for ya first! :headbang:
they are 10x4's that I want to put on my HS banshee hillshooter. The spindles look pretty close. I have been told that they will and wont work so I am just trying to figure out prior to buying them. They are HS spindles but I am pretty sure HS uses the same sindles as a OEM banshee. Thanks for all your help.
