I just installed a set of lonestar +2 a arms. I can tell that is has pushed the front tires forward about two or three inches. Is this normal or did I do something wrong. Thanks.
Sounds like you put the arms on the wrong side. Try changing them from one side to the other bud :cheers: Should be +1 forward per side and +2 out per side.
I am adding some pics. This is on the right side. I hope I didn't put them on backwards. I bought a banshee that these came on so I switched them out onto my bike. I thought I was doing the smart thing by taking off the a-arm and putting it right onto my bike so I wouldn't mix them up. Now I am thinking what if someone else put them on backwards.
I just looked at mine...your good. Think about it...if you put the lower on the other way, it would be behind the original wheel position. Did you set it up according to Lonestar specs?
http://www.lsracing.com/img/Guide_21.pdf
If it was installed wrong, you couldn't attain the proper camber/toe.
