sapient Posted April 21, 2010 Report Posted April 21, 2010 I have a 34mm Keihin PJ 07babg that is on my blaster... I'm wanting another 34mm carb that will sync up with the one ive got for my banshee.... Anyone have what I need or is this not a good idea? I'm not sure. I'm getting a 72mm Big Bore, with a port and polish and Im afraid the stock carbs are going to run it too lean. I'm willing to trade the stock carbs with tors for one 34mm also. Quote
tundish2800 Posted April 21, 2010 Report Posted April 21, 2010 I would say that you should get some 39s thats a big bore motor and 34 might choke it. Quote
Darthwall Posted April 21, 2010 Report Posted April 21, 2010 x2 on that coment 34's will probably run it but 39's will bring it to life Quote
sapient Posted April 22, 2010 Author Report Posted April 22, 2010 Well, I ended up buying another 34mm for now... I've already spent way too much on everything else, and I just want to get it running. Running 34mm isn't going to run it lean to the point where it burns up will it? Or am i just confusing choke with lean? You can choke it without it running lean? Quote
tundish2800 Posted April 22, 2010 Report Posted April 22, 2010 The motor will run it will just not get peak performance with those carbs. The 39s will let it breathe and run like a raped ape. Just jet it right and you will not have any problems Quote
sapient Posted April 22, 2010 Author Report Posted April 22, 2010 Thanks, thats what I needed to know. I'll get it running like a raped ape later Quote
