How does the stock banshee air filter flow compared to a aftermarket foam style filter on a air box with a generous amount holes in the lid?
Im just trying to decide if I should hold off on a better air filter or not Im just concerned the stock filter might restrict flow but im not sure.I know it probably doesnt filter as well but I clean it frequently anyway
the stock cage, which the filter sits around is crap. the foam seal on the end leaks and youll get shit in your motor.
an after market one like the noss/pd one has an o-ring seal and its bolted to the air box so it will never leak. and you can run it without the lid.
you will have to re jet the carbs to run it without the airbox lid.
you can get vents from FAST for your airbox.
Thanks for answering my question I think my jetting would be ok with no lid I put so many holes in my lid and my mains are 310s and pilots 27.5 but hey you never know
