VictorK Posted April 16, 2010 Report Posted April 16, 2010 How does the stock banshee air filter flow compared to a aftermarket foam style filter on a air box with a generous amount holes in the lid? Quote
VictorK Posted April 16, 2010 Author Report Posted April 16, 2010 Im just trying to decide if I should hold off on a better air filter or not Im just concerned the stock filter might restrict flow but im not sure.I know it probably doesnt filter as well but I clean it frequently anyway Quote
dirtydownunder Posted April 16, 2010 Report Posted April 16, 2010 the stock cage, which the filter sits around is crap. the foam seal on the end leaks and youll get shit in your motor. an after market one like the noss/pd one has an o-ring seal and its bolted to the air box so it will never leak. and you can run it without the lid. you will have to re jet the carbs to run it without the airbox lid. you can get vents from FAST for your airbox. Quote
VictorK Posted April 17, 2010 Author Report Posted April 17, 2010 the stock cage, which the filter sits around is crap. the foam seal on the end leaks and youll get shit in your motor. an after market one like the noss/pd one has an o-ring seal and its bolted to the air box so it will never leak. and you can run it without the lid. you will have to re jet the carbs to run it without the airbox lid. you can get vents from FAST for your airbox. Thanks for answering my question I think my jetting would be ok with no lid I put so many holes in my lid and my mains are 310s and pilots 27.5 but hey you never know Quote
