slamed91si Posted April 11, 2010 Report Posted April 11, 2010 anyone know if a rear caliper from a 07 yfz450 will bolt up on a banshee i want somthing with dual pistons Quote
NickisGod Posted April 12, 2010 Report Posted April 12, 2010 well u wanna put a yfz caliper on a shee huh? well i was in the works of doing so untill i relized how much p.i.t.a. it would be to convert over. well i mean its not a huge ordeal but i stayed on the beaten path when upgrading my rear caliper and used a 250r caliper insted. why? because it just make sence. i wrote a tutorial on how to do so http://bansheehq.com/forums/index.php?showtopic=128874&st=0&p=1112690&fromsearch=1entry1112690 the issues i seen with using a yfz caliper was that i would need a special made brake stay ontop of a custom rotor to couple on my banshee hub. to make life easier just use a 250r brake stay, all u gotta do is remove alittle material from the brake stay vs desiging and custom cutting one. pm if u got some more questions i could help u out if u wanna setup like mine/ Quote
slamed91si Posted April 13, 2010 Author Report Posted April 13, 2010 cool wright up man thanks for the info but i dont have a round house swing arm and dont want to buy one just to make the 2 piston work so i guess im stuck with a single piston thanks again Quote
