What type of aftermarket exhaust do you have? T5 with toomey silencers
2) What type of airfilter do you have? K&N
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock air box no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com sea level
5) What size pilot jets are you using? stage 2 dynojet
6) What size main jets are you using? i think 280 stage 2 dynojet
7) What temperature is your Banshee jetted for? i run all year from 0 to 90 degrees
8) Do you have a port job? herr jugs agressive mx port job
9) What kind of carbs? stock
10) What size carbs? stock
11) chariot performance billet reed cage with boyeseen dual stage reeds
12) +4 advanced timing
13) noss cool head with 23mm domes
14) 4mill stroker kit from herr jugs
15) billet intake with built in crossover from chariot performance
0 hours on this motor, isnt even assembled yet just looking for a kit to jet me in the right range.
any help would be appreciated.
Thanks,
Mike
