Up for sale is New never been put together 4 mil DM 555 cc's
Top end:
78 bore Cylinders-drag ported by Trinity Racing
All gaskets and O-rings
Wiseco pistons and rings and wristpins
Head and domes
Exhaust Flanges
Reed adapters
UPP intakes
V-Force 3 Reeds and gaskets
Stud adapter for the cylinders
All studs and nuts for the head and small 10mm 12 point nuts for the cylinders
Cases epoxied and welded for the DM
The cases have the strut brace that attaches to the frame to keep the motor from twisting
I also have a seal kit (not pictured) for the cases
Wiseco crank with max load TZ bearing
2-5 Overide with billit second also have forks and all bearings (not pictured) but are inside the cases
All new bolts, washers and clips for the clutch
Kicker gear
Billit water pump
Water pump cover and gasket
Clutch cover gasket
Stator, flywheel and timing plate
Clutch basket, inner hub, pressure plate, shift shaft and clutch springs
Wiring harness, dynatek adjustable CDI
There may be some things that I am leaving out but everything is here to put the engine together except the side covers.
I am asking 3500.00 plus shipping and may be negotiable
Feel free to call me at (252) 723-5578
th_4milDM047.jpg7/th_4milDM051.jpg[/img][/url]
