banshee4201
    92 banshee 68mm cub cylinders stoke crank, long rod lightened flywheel 35's pwks in frame drag CPI's trinity intakes delta v-force reeds trinity head 18cc domes 110 octane, redline oil
banshee4201's Achievements
  1. anything i got is for sale...lol
  2. Up for sale is New never been put together 4 mil DM 555 cc's Top end: 78 bore Cylinders-drag ported by Trinity Racing All gaskets and O-rings Wiseco pistons and rings and wristpins Head and domes Exhaust Flanges Reed adapters UPP intakes V-Force 3 Reeds and gaskets Stud adapter for the cylinders All studs and nuts for the head and small 10mm 12 point nuts for the cylinders Cases epoxied and welded for the DM The cases have the strut brace that attaches to the frame to keep the motor from twisting I also have a seal kit (not pictured) for the cases Wiseco crank with max load TZ bearing 2-5 Overide with billit second also have forks and all bearings (not pictured) but are inside the cases All new bolts, washers and clips for the clutch Kicker gear Billit water pump Water pump cover and gasket Clutch cover gasket Stator, flywheel and timing plate Clutch basket, inner hub, pressure plate, shift shaft and clutch springs Wiring harness, dynatek adjustable CDI There may be some things that I am leaving out but everything is here to put the engine together except the side covers. I am asking 3500.00 plus shipping and may be negotiable Feel free to call me at (252) 723-5578 7/th_4milDM051.jpg[/img][/url]
  3. Its not a bad thing, I sold them guys down that way some bikes.....If its the same people
  4. I thought this thing looked familiar.
  5. who did you get this bike from? Was that track in Wallace NC
  6. I,ve got a black rear set of Maier.
  7. I just met up with him today, bought a rigid frame off of him. Super cool guy.....I don't or haven't seen any problems with his dealings. He met me half way, everything went great.
  8. I was just wondering if the billet bowls on the lectrons get in the way of the clutch cable or anything? I will be running 44mil lectrons. Thanks for any input..
  9. This is the only one that i have, sorry.
  10. Idk what happened to the links but...
