okay i have a 421 cub cylinders 490.00
4 mill rebuilt crank hours unknown hotrods 290.00
pro design timing plate 50.00
cascade stator cover 110.00
cascade gear slammer shifter 38.00
pwk 35mm with cable/and beat up filters 290.00
vforce3 reeds and cages 175.00
vforce3 reeds and cages with stuffers 175.00
cases/chain wack but does not leak at all 90.00
billet intakes 110.00
direct drive lock up and cover with water pump cover and cascade dip stick 280.00
+12 ss brake line with ris design lever polished master cylinder,and polished brake rezzy,polished rear caliber,aftermarket wave brake rotor 125.00
shear same side (left) small bore chrome oof 450.00
lectrons w/billet bowls 36/38 alky 375.00
also a stock motor wit all polished ,coolhead,adj timing plate 1200.00
all pic on photobucket
you can reach me by text are call 229-869-9821 the name is jason i do have some feed back on here check it out
my paypal is [email protected]
http://s840.photobucket.com/albums/zz326/JasonRobarts_2010/?action=view&current=IMG_3757.jpg
i will ship usps the next day when money clears and on mass amount i will insure with delivery confirmation. thanks for looking
cascade stator cover 110.00===================SOLD
cascade gear slammer shifter 38.00=====================SOLD
Do you still have the cascade stator cover?
cascade stator cover 110.00=======================================SOLD!!!!!!
cascade gear slammer shifter 38.00======================================SOLD!!!!!
pwk 35mm with cable/and beat up filters 290.00==============================SOLD!!!!!!!
vforce3 reeds and cages 175.00==============================================SOLD!!!!!!!!
billet intakes 110.00===================================================SOLD!!!!!!!!!!!!!!
direct drive lock up and cover with water pump cover and cascade dip stick 280.00=============SOLD!!!!!!!!
shear same side (left) small bore chrome oof 450.00==================================SOLD!!!!!!!!!!
lectrons w/billet bowls 36/38 alky 375.00==========================================SOLD!!!!!!!!!!!!!
cpi oof one out each side black excellent condition small bore w/brackets to mount 350.00
