-Herbie- Posted March 24, 2010 Report Share Posted March 24, 2010 just put motor back in bike after pc'ing frame, motor wasn't opened up and ran good before. only new item is cool head with 20cc domes. had it started briefly on sat. but didn't run well, now won't start. has spark and plug smells of fuel. while plugs were out kicked it a couple times, then put plugs back. 1st kick after that it wanted to fire then by 4th kick no go. leads me to belive its getting too much fuel. carbs were just cleaned and floats set last night. jets are 27.5 pilot and 280 main at sea level with FMF pipes any suggestions? Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 24, 2010 Report Share Posted March 24, 2010 you just got your frame powder coated, did you sand off a place for your ground wire and the two tabs your coil mounts up to? i ve seen a lota ppl just forget to do that and its whats causing no running or shitty running Quote Link to comment Share on other sites More sharing options...
-Herbie- Posted March 24, 2010 Author Report Share Posted March 24, 2010 you just got your frame powder coated, did you sand off a place for your ground wire and the two tabs your coil mounts up to? i ve seen a lota ppl just forget to do that and its whats causing no running or shitty running ahh! no i didn't, good call will try that thanks. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 24, 2010 Report Share Posted March 24, 2010 no problem Quote Link to comment Share on other sites More sharing options...
