slickrick Posted March 23, 2010 Report Posted March 23, 2010 Hello everyone I need help choosing a front and rear sprocket for my 01 banshee. I just hillshoot. (race)My mod are as followed. -T's 5 -k&n airfilter - +4 timing advance -v vorce reed -ported cylinders -head rechambering -.20 pistons -white bros boost bottle -stock carbs. Bike made 62 HP on the dyno..... Anyhelp is apreciated. thanks! Quote
SAVAGE420 Posted March 23, 2010 Report Posted March 23, 2010 You run 14/41 (stoke) yet? Could try a 15 out front and see if you like it. Quote
slickrick Posted March 23, 2010 Author Report Posted March 23, 2010 You run 14/41 (stoke) yet? Could try a 15 out front and see if you like it. i HAD 14/41 stock before i did my porting. For some reason i decided to go to 13-41 but i hate it.. LOL So i dont know if i should go back to stock 14/41 or go 15/41. What the difference? I just hillshoot....... Quote
Sandfrk33 Posted March 24, 2010 Report Posted March 24, 2010 One tooth bigger will make each gear alittle longer. Increase top speed. I'm not sure what you would use just for hillshooting. Try a 15. They're cheap and easy to change. I run 15/40 on my dune bike. Quote
