emerson750 Posted March 19, 2010 Report Posted March 19, 2010 I recently bought a banshee that needed a new topend. I rebuilt it and now am ready to fire it up. it is bored .80 over , has dg pipes , boysen radd valves & reed spacers, k&n filter with adapter. the mains are 290 , 25 pilots the lid is on with snorkel and 2x4 hole cut in lid Im at 603ft in Illinois and would like to run with the lid off so my question is where should I start . Thanks Anthony Quote
MN SHEE Posted March 19, 2010 Report Posted March 19, 2010 I have T5 pipes and run 27.5 piolets and 340 mains untill I switched carbs. I am shure some one else wil chim in with a better answer for some reson I was always had to be jetted fatter than all my buds Quote
SAVAGE420 Posted March 19, 2010 Report Posted March 19, 2010 I would say you could go up too a 300-310 main and should have a 27.5 pilot probably. You could also do a plug chop and see where your at on your mains for piece of mind if your not confident going by feel. http://www.dfn.com/benkaren/plugchop.html Outside temp plays a big roll in jetting also. You can also look through a ton of other people setups and jetting right here also. http://bansheehq.com/forums/index.php?showtopic=99361 Thats stickied at the top of this sub forum Quote
