Im trying to get the steering stem bearing out its spent but the holder wont budge I pb blasted it a few days tried to heat the shit out of it too my tool is a nut with a bolt welded to it I grinded to match the bearing holder did any of you have this issue?
i put two nuts together on a piece of threaded bar then welded them together and then used a socket and impact gun , mine was stuck in there pretty bad but with the impact and a bit of heat it came out relatively easy
thanks bro the impact is the help I was looking for i cant believe I didnt think of that
Thanx to BHQ you got it done. :headbang:
Welcome by the way.
oh yeah, i had a minor brain melt and forgot to welcome you to the HQ :cheers:
everything and anything you want to know about your shee can be found here, this site is the shizzle :headbang:
I used the impact gun like you said it worked great thanks now I can start putting my rolling chassis back together then get nice heads to go with my new pistons
no problem, glad i could help :cheers:
