Can anybody give any advice on the best spark plugs for a stock 2004 Banshee. I would also like it to run a little cooler, seems like it was running a little hot a time or two the other day. Any suggestions on coolant? I just bought my first Banshee a couple weeks ago so im kinda new to them. Rode the past two weekends and I love the Banshee.
Well welcome to the HQ! I run the stock plugs on my 'Shee they're B8ES and I run whatever coolant is cheapest at the local auto parts store by my house, I've run a few different types of coolant and none of them seemed to run cooler than the other. The only difference is how quickly the heat is transfered, not the temperature itself. And it isn't even a noticeable difference from what I could tell.
I run NGK Br9EYA runs good with them. I just get the cheap coolant at wal mart and run it. They make an aluminum piece you can put in your main coolant hose that goes to the motor, that will help with heat dispertion. I run one i thinks its made by pro design but modquad makes one too.
