I'm not sure how to word this but I'll try. I'm running my shee at 40:1 and its a little rich, but when I run 50:1 it seems to be dead on, my question is it is better to run 50:1 or rejet to run at 40:1, I'm not loking for mad power just whats good for the motor. Is running the bike at 50;1 the same as rejetting it to match 40;1? I hope this makes sense?
What oil do you run?
When you say your rich, do you mean oil rich or fuel rich.
Because at 40:1 there is LESS fuel going into the motor (leaner amount of fuel) but more oil (richer). AND with 50:1 there is less OIL going into the motor (leaner oil) but more fuel (rich)
Understand the diff in the two?
Anyways if your running a full synthetic oil 50:1 is fine
I run Amsoil Interceptor at 50"1 for years and there no problem. Thats what they call for.
If your running (dino) standard oil then i would run it at 32:1.
My plugs are dark as if to much oil, and I run kloz R-50, Should I just run at 50;1? thanks
Sure.
I run 50:1 ,so do lots of people.
Sure.
I just run lots of hard trails and wanted to make sure I was not hurting anything first! but thanks man
