BigMatt Posted March 10, 2010 Report Posted March 10, 2010 I was not sure where to post this but, I have pod filters and just got my outterwears in but I notice this nub coming off the frame on both sides and its rubbing on my filter. Is this where the stock pipes mounted or maybe part of the airbox, Have you guys just shaved these off or left them.? thanks Quote
08 BANSHEE Posted March 10, 2010 Report Posted March 10, 2010 I was not sure where to post this but, I have pod filters and just got my outterwears in but I notice this nub coming off the frame on both sides and its rubbing on my filter. Is this where the stock pipes mounted or maybe part of the airbox, Have you guys just shaved these off or left them.? thanks Pics would help, its most likely from the airbox, I don't think its too big of a deal unless they vibrate up and down to cut a whole in them, also, if your not gonna run an airbox, and the tabs are from the airbox, cut 'em off Quote
springer Posted March 10, 2010 Report Posted March 10, 2010 cut em ff. i had the same issue and they rubbed holes through my outer wears and wore on the filters. i just cut them off. dont know exactly what they were for, but haven't needed them since... Quote
SAVAGE420 Posted March 10, 2010 Report Posted March 10, 2010 Yeah, those are for where the front of the air box sits. I cut mine off flush also. You can also lightly zip tie your pods together so they dont rub against the stingers also and burn over time. Quote
BigMatt Posted March 11, 2010 Author Report Posted March 11, 2010 also to stop the pipes from burning a hole in my new outterwears whats the pipe rap some of you use and where do you get? Quote
SAVAGE420 Posted March 11, 2010 Report Posted March 11, 2010 also to stop the pipes from burning a hole in my new outterwears whats the pipe rap some of you use and where do you get? Cascade carry's some. But all you need to do is like i said and zip tie your filters together lightly. OR you can just go to any auto parts store and get some header wrap. Stuff is real cheap and takes seconds to put on. Quote
BigMatt Posted March 11, 2010 Author Report Posted March 11, 2010 Cascade carry's some. But all you need to do is like i said and zip tie your filters together lightly. OR you can just go to any auto parts store and get some header wrap. Stuff is real cheap and takes seconds to put on. I think I'll try the header wrap, I know it holds water but the trails I ride are mostly sandy dirt so I'll be good, I just thought zip ties might wear threw. thanks man Quote
