What size of main jet do u think i should put
sketch2
Hey guys Iam getting my jet kit in 2marrow from vitos and i was wondering what size do you think i should use it has the stock carbs and it has 200's in it. but i have a fresh bore on stock cylinders of 0.60 and has wiseco pistons, boost bottle, toomey 2>1 filter kit, fmf fattys with power core 2's, and my elevation is at 6,969 ft
27.5 pilots. 1-1/2 turns from fully seated. Needle in the middle. Mains I would startout at 310 if ur cold if ur in the 60's or higher, try 300. That should get u in the park to start. But ur elevation is going to get you. But what temps areu seeing right now?
