tecateman Posted February 26, 2010 Report Posted February 26, 2010 im going to start building my motor from scratch. all new aftermarket parts except cases... if i have a cylinder,crank etc sitting for a few months until its all together.... will i need to worry about rust? basically i want to assemble all my parts first and then powdercoat and polish everything before i assemble. im just unsure. new parts should be ok i hope? Quote
zach45 Posted February 27, 2010 Report Posted February 27, 2010 crank be fine... leave it in the packaging.... it comes in a bag with some oil in it... jugs i put a little bit of oil on my finger then coat the cylinder walls Quote
tecateman Posted February 27, 2010 Author Report Posted February 27, 2010 thanks. what about everything else? trans parts,clutch parts etc? im not sure which parts are aluminum. Quote
zach45 Posted February 27, 2010 Report Posted February 27, 2010 should be fine,... if you wanna you could get a plastic shoe box.. dump a quart or 2 of trans fluid and lay the tranny in there.... but i wouldent worry Quote
alcoholbanshee Posted February 27, 2010 Report Posted February 27, 2010 Just spray anything you are worried about with WD40................problem solved!!!!!!!!!!!!!!!!!!! Quote
