So im rebuilding the top end and my jugs seem to not fit over the pistons very eaisly they have been bored and honed and the machine shop had the pistons with them when they did it. I got one of them on a little bit and it was still very hard. It almost seems like they dont fit
there is a small pin looking deal in each ring groove, make sure that the break in the ring pinches this little pin. if not you will never get those pistons on, it can be a little tricky but after you get it on you will wonder why you couldn't have figured that out before.
You better stop there and test fit the pistons. I have seen this myself where the shop does not take the time to test fit. I got one back with .005" taper!! Without rings, the pistons should just fall through the hole. If they do not, do NOT run them. Also, as mentioned above, make sure your rings are in their home about the locate pin in the ring lands.
IMO, if the ring end gap is way off, there is something wrong with the bore, not the rings. Wiseco has been pretty accurate on rings for some time.
Mull Engineering
[the rings are in there home lol and they are vitos pistons
Vitos does not roll their own. They have Some wiseco and some other lines. Check the bottom of the wrist pin boss for a "W" or post a pic and I can likely help.
