Thewhite Posted February 13, 2010 Report Posted February 13, 2010 Last time that I did it, I used a zip gun to push the bolt about 4'' and I cut the other end. Then repush the bolt about one inch to clear the frame and the swing arm will free fall on the ground. You will need a new sleve and bolt. Quote
MILO Posted February 14, 2010 Report Posted February 14, 2010 (edited) yep, just cut that bitch out of there. you can pound on it for days and not get it out. if i remember correctly you need to chisel off the dust covers and then you can get to the bolt between the swinger & the frame. do one side first then the swinger will float enough to get to the other side. just be sure to put some good antisieze on everything when you put it back together and check it/lube it frequently. Edited February 14, 2010 by MILO Quote
