twizted269 Posted February 8, 2010 Report Posted February 8, 2010 will the everything internally work in all years or is everything year specific? i know the gear ratios are different but will it all work if you swap everything over from another bike? also does anyone happen to know if its the same with the warrior? looking to rebuild transmissions in both bikes out of newer machines. Quote
robert0762 Posted February 8, 2010 Report Posted February 8, 2010 I'm pretty sure that the gears are all the same regardless of year. What changed was sprocket size Quote
twizted269 Posted February 8, 2010 Author Report Posted February 8, 2010 both machines are 88 so im looking to see if one from say a 97 or newer would work if i swap out everything internally. Quote
bansheesandrider Posted February 9, 2010 Report Posted February 9, 2010 All years of Banshees have the same gears inside the motor, including the gears under the clutch cover. The only gearing change ever made to a Banshee was the sprockets for the chain. You can use one piece or the entire transmission in any year Banshee. That being said, it would be better to swap entire transmissions because each gear would be running against the same gear it is already wore to, same with the shift forks, shift drum, and the shift dogs on the gears. As for the Warrior, I don't know, but I would think you could probably swap entire transmissions just fine. Quote
