hi guys i have a quick question about the banshee electrical system, i am in the current state of building a dirt oval banshee, there are no rules for the open class and i am experimenting with a right front brake lock out solenoid, the solenoid is powered by 12 volt dc, now here's where it gets interesting in an attempt to hide the solenoid i have it mounted behind the radiator just infront of the fuel tank mount on the left side, i would like to be able to use the high low beam switch on the handle bars to run the relay and use the power wires going to the tail light to illuminate a small press in cat eye bulb on the rad shroud, do you guys think this will work
