been reading a few post lately on forged pistons and machined there are different tolerances when boring by the sounds of it. where do you find these specs and also can you check piston the cylinder gap with some feeler gauges? what pistons last the longest. historically ? i know they can all fail but
Edited by yamaha04
I would guess you can get the specs from the manufacture. You can not check the piston to cylinder clearance with feelers. You need a bore gauge to measure the cylinder and a dial mic for the piston, then you do the math to get your clearance.
Pistons are like tadder chips, every one has a kind they like, and a kind they hate, and a million reasons why they do. If your using a builder, go with what they recommend.
