Wellsy Posted January 22, 2010 Report Posted January 22, 2010 Hi Guys Please could you advise on the approximate jet, pilot and needle I would need given the engine spec and current temperature here in the UK. Currently the temperature is approx 8 degrees Celsius or in Fahrenheit approximately 47 degrees. Engine and ancillary details Vito's superstock piston .60 over Standard cylinders Vito's Hemi Head (unsure of dome CC) Vito's 4mm stroker crank PJ34 Keihin Carbs K&N single filter in standard air box with lid on FMF Exhaust (Powercore) 0 degree advanced timing but have Ricky stator CDI 98 Octane Fuel Platinum plugs *No porting Any help would be welcomed Thanks in advance Quote
Wellsy Posted January 22, 2010 Author Report Posted January 22, 2010 Sorry guys forgot to add I have Vforce3 reeds and a boost bottle Quote
