Awhile back I bought a set of newer calipers off a 2001 or so banshee, and obviously they dont fit my older 87' spindles. If I bought some new spindles/hub assemblys from a newer banshee, would they go onto my J-Arms just fine? Then I could install te new brakes?
Here is what i ran into when i did this swap just a month ago. i have a 95' chassis so i had all parts on hand. Well the newer calipers will obviously only bolt to the newer spindles so you know you need those. I also noticed on my 87 hubs,the bolts that hold the front discs on stick out pretty far,and the bolts that hold the discs on the newer hubs are more recessed. So when i went to put the 87 hubs on the bolts hit the spindle,so i had to use newer front hubs too.
I dont know if they are all like this,but mine were.
