400rednEX Posted January 19, 2010 Report Posted January 19, 2010 parting out the whole machine. pm me about other parts you want, 2nd gear is broke on the tranny. i can email you pics if i can't get them to post. Ferryville, WI 54628 v force 3 reeds, about 6 dune trips $125 shipped fmf ram valves with 2 dune trips on reeds $50 shipped vortex billet basket with primary gears, fast clutch- 2 steels have bluing, inner hub and pressure plate, washers and such. about 6 dune trips on all these pieces. complete setup $150 shipped modquad lockout and cover, cover is complete with waterpump. seeps oil at lexan cover $175 shipped cylinders with gorr's "more better everywhere" porting, 65.25mm wisecos, studs and nuts have about 4 dune trips on them. with included .110 cut and redomed stock head these make 165psi $275 shipped factory crank welded by f.a.s.t. was a low hours take out when jeff welded it and i put about 4 dune trips on it after. $150 shipped black fullbore rear fenders $120 + shipping trinity single carb setup with a 38mm pwk airstryker, almost new carb boot, pod filter w\outerwear, and braided throttle cable. twist throttle included if you want it. $250 shipped fmf gold pipes with newer fmf turbine core internal sparky silencers. pipes aren't perfect but look pretty decent. there's a weld and a couple scuffs on the chambers. silencers nice. $150 shipped durablue+2+4 axle with hubs, rotor,sprocket,stock carrier with newer bearings in it. $160 shipped. pep steering stabilizer with hardware. $25 shipped engine cases, no breakage, but small grooves where the crank pins cut in at one time. they were like that the whole time i ran them without problems. newer tranny bearings included $150 shipped. 87-94 stator with adjustable timing plate $75 shipped stock flywheel $50 shipped stock radiator and hoses $20 shipped stock coil & wires $20 shipped newer stock rear shock $45 shipped frame and stock swinger for $200 if you can pick it up from 54628 Quote
400rednEX Posted January 19, 2010 Author Report Posted January 19, 2010 Where r u located ferryville wi, zips at the top of the post Quote
wizeass2005 Posted January 19, 2010 Report Posted January 19, 2010 pics of lock out and cover to [email protected] please! Quote
nastyracing Posted January 19, 2010 Report Posted January 19, 2010 ferryville wi, zips at the top of the post Dibbs on lock out n clutch cover give me a caLl on my cell we will finish this deal 908 601 1891 names joe may also be interested in full bores definetly want lock out we will finish this deal Quote
MikeNick Posted January 19, 2010 Report Posted January 19, 2010 Hey man is that PEP stabilizer in good shape and does it need rebuilt or is it even rebuildable..Post up a pic or send me 1 to [email protected] Quote
wizeass2005 Posted January 19, 2010 Report Posted January 19, 2010 Dibbs on lock out n clutch cover give me a caLl on my cell we will finish this deal 908 601 1891 names joe may also be interested in full bores definetly want lock out we will finish this deal Come in and call dibs on something 11 minutes after I just did??? WTF??? Quote
JCMshee Posted January 19, 2010 Report Posted January 19, 2010 Do you have a seat? If so how much? Quote
400rednEX Posted January 19, 2010 Author Report Posted January 19, 2010 Hey man is that PEP stabilizer in good shape and does it need rebuilt or is it even rebuildable..Post up a pic or send me 1 to [email protected] its in pretty good shape and still seems to work. i don't think it's the rebuildable one. pics sent Quote
400rednEX Posted January 19, 2010 Author Report Posted January 19, 2010 Do you have a seat? If so how much? it is the original factory black seat with a few rips, the biggest one being a 2" Y shaped one on top. $25+ shipping. need pics? Quote
phive70 Posted January 19, 2010 Report Posted January 19, 2010 can you please send pics of the rear axle assembly to [email protected] ? thanks Quote
alexmarq1986 Posted January 19, 2010 Report Posted January 19, 2010 hello, i need the radiator hoses if you can separate from radiator. Please send me price shipped to 79022. Thanks Quote
MikeNick Posted January 19, 2010 Report Posted January 19, 2010 its in pretty good shape and still seems to work. i don't think it's the rebuildable one. pics sent I'll take it man..Whats your paypal.. Quote
carlcidortiz Posted January 19, 2010 Report Posted January 19, 2010 parting out the whole machine. pm me about other parts you want, 2nd gear is broke on the tranny. i can email you pics if i can't get them to post. Ferryville, WI 54628 v force 3 reeds, about 6 dune trips $125 shipped fmf ram valves with 2 dune trips on reeds $50 shipped vortex billet basket with primary gears, fast clutch- 2 steels have bluing, inner hub and pressure plate, washers and such. about 6 dune trips on all these pieces. complete setup $150 shipped modquad lockout and cover, cover is complete with waterpump. seeps oil at lexan cover $175 shipped cylinders with gorr's "more better everywhere" porting, 65.25mm wisecos, studs and nuts have about 4 dune trips on them. with included .110 cut and redomed stock head these make 165psi $275 shipped factory crank welded by f.a.s.t. was a low hours take out when jeff welded it and i put about 4 dune trips on it after. $150 shipped black fullbore rear fenders $120 + shipping trinity single carb setup with a 38mm pwk airstryker, almost new carb boot, pod filter w\outerwear, and braided throttle cable. twist throttle included if you want it. $250 shipped fmf gold pipes with newer fmf turbine core internal sparky silencers. pipes aren't perfect but look pretty decent. there's a weld and a couple scuffs on the chambers. silencers nice. $150 shipped durablue+2+4 axle with hubs, rotor,sprocket,stock carrier with newer bearings in it. $160 shipped. pep steering stabilizer with hardware. $25 shipped engine cases, no breakage, but small grooves where the crank pins cut in at one time. they were like that the whole time i ran them without problems. newer tranny bearings included $150 shipped. 87-94 stator with adjustable timing plate $75 shipped stock flywheel $50 shipped stock radiator and hoses $20 shipped stock coil & wires $20 shipped newer stock rear shock $45 shipped frame and stock swinger for $200 if you can pick it up from 54628 Please email pics of the modquad lockout and Vforce 3 to [email protected] I'm really interested Quote
rusty1100 Posted January 20, 2010 Report Posted January 20, 2010 I'll buy the flywheel from you. Do you have any pictures of it, if so please send them to [email protected] Thanks. Quote
