THIS IS A FRESH TWISTER BILLET CYLINDER MOTOR 546CC 75.5MM BORE AND 7MM STROKED MOTOR CARBS AND ALL!!! SET IT IN YOUR FRAME AND GO. IF YOU REMOVE THE SPARK PLUG YOU CAN READ THE #'S ON THE PISTON AND ITS CLEAR AS DAY THIS MOTOR HAS HAD 3 PASSES MADE ON IT SINCE IT WAS REBUILT.
POLISHED BILLET TWISTER CYLINDERS
NEW TWISTER BILLET CRANK
41.5 KEIHN PWK WITH POWERJETS SET UP TO RUN ALKY
HINSON 8 PLATE CLUTCH BASKET
STRAIGHT CUT GEARS
1-5 CUT TRANSMISSION
DIRECT DRIVE LOCK UP CLUTCH
V FORCE 3 REEDS
POLISHED STATOR COVER
GMS BILLET KICK STARTER HAS A LITTLE RASH FROM PEG.
POLISHED CLUTCH COVER
BILLET GEAR SLAMMER SHIFTER
