Why the motor of some Banshee are so noisy?? I mean you can think that it's broken or diesel motor?? Is the oil important here?? I owned a 2000 Banshee and the motor was not so noisy than my actual 2005 Banshee motor. Please anyone that can give an opinion.
Worn internal parts. Several things can cause engine noises, the most common being piston slap, worn clutch baskets and worn crank bearings. Some noises can be caused by modifications: open filters will be noisier than an airbox setup, straight cut gears are noisy ect. ect.
A shorter tuned length fatter pipe will be louder as well more ping if you will, a pipe sitting on the lower frame rail or exhaust hanger like most CPIs for example as well as many others, rattly kickstarter, higher compression, raised exhaust port, a bike with advanced timing will be quieter and all the other reasons Brandon listed all can make one louder. My 4mil Cub is fairly quiet with my timing and running kinda fat on alky.
well I'll need to open the motor of my banshee to know about it, I bought the banshee and the guy told me that it was stock just the VForce and FMF Gnarly with powercore 2. Do you think that could be have some worn parts, the shee run perfect.
I have FMF Gnarly with powercore 2 , do you think that set up could cause this noise???
