nigels_world Posted December 25, 2009 Report Posted December 25, 2009 I just moved from high elevation in hot Arizona to sea level in cold Maine so I'm obviously going to be way lean. I have no idea where to start but am totally confident that I can tune it once I have a starting point. Like I said I'm at sea level (I live right on the ocean) and the temps have been 15-35 degrees f. Specs for the banshee are: ported jugs (I have no information about them) v force 3 reeds rz350 carbs fmf pipes k&n pods (no box) stock timing where do I start? Quote
shakar Posted December 25, 2009 Report Posted December 25, 2009 (edited) I just moved from high elevation in hot Arizona to sea level in cold Maine so I'm obviously going to be way lean. I have no idea where to start but am totally confident that I can tune it once I have a starting point. Like I said I'm at sea level (I live right on the ocean) and the temps have been 15-35 degrees f. Specs for the banshee are: ported jugs (I have no information about them) v force 3 reeds rz350 carbs fmf pipes k&n pods (no box) stock timing where do I start? im also in maine coast with about the same set up as u - the port and im running 350 mains 27.5 pilots im a lil rich there. i hope this helps man . where u liv at? i hope u like freezing ur balls off brrrrrrrr welcome Edited December 25, 2009 by shakar Quote
SAVAGE420 Posted December 25, 2009 Report Posted December 25, 2009 http://www.dfn.com/benkaren/jetfaq.html Quote
nigels_world Posted December 26, 2009 Author Report Posted December 26, 2009 Shakar - I live in Franklin, right next to Ellsworth. How about you? I grew up here so the cold is familiar. Savage420 - that's always a good read. Quote
sleeper06 Posted December 26, 2009 Report Posted December 26, 2009 350 mains are safe as long as the port isnt too aggressive,27.5 pilots Quote
AKheathen Posted December 27, 2009 Report Posted December 27, 2009 what was your jetting for az? i would guess you would be moving up 3-4 sizes on the mains and mabey 1 on the pilot, but the fuel at higher elevations and elevation change both will affect it also. i'm guessing it was about 3k in az? that would bring you up some and the fuel differences will bring you down some.... Quote
nigels_world Posted December 29, 2009 Author Report Posted December 29, 2009 what was your jetting for az? i would guess you would be moving up 3-4 sizes on the mains and mabey 1 on the pilot, but the fuel at higher elevations and elevation change both will affect it also. i'm guessing it was about 3k in az? that would bring you up some and the fuel differences will bring you down some.... Actually I was at 4700 feet. I was at 310-25 on the jetting there. Quote
sleeper06 Posted December 29, 2009 Report Posted December 29, 2009 Start rich at 360 you could be close,27.5 pilot Quote
