MatHolland Posted December 10, 2009 Report Posted December 10, 2009 As some of you may know, I just got this 02 banshee. Only mods (that I know of) are Toomey t6 exhaust Airbox with airlid removed and K&N air filter It will not idle. K&N pods are on the way. I am not sure what jets are installed in it, but does it sound like the pilot jet might be clogged or too small? Maybe carbs aren't in sync? I don't have the tool, but how exactly do I sync the carbs without the vaccum tool?? I know you make it where the domes bottom out, then you do a WOT and alighn the black dot in the center glass, but what screws do i use? TORS boxes are still installed, however the system is not hooked up. Quote
