This is a pile of part that I have laying around after a Banshee Part out as you can see
there are a lot of parts for a Banshee here. All parts are used and in usable condition.
Any questions feel free to ask. Thanks. There is a lot of stuff here for a great price.
$75 for everything listed below.
Header pipes
Set of mid section to exhaust with heat shields
Extra mid pipe
Ignition coil with fit all year banshee's
4 Axle Nuts
Steering Stem mount clamp
Coolant hose from cases to head
5 air box to carb mounting boots for intake
Other misc rubber mounts/covers
Swingarm pivot caps
Swingarm pivot chain roller metal bushing
Clutch lever and perch
Front brake lever
Clutch springs
Kill/Light switch
1 black set of handle bar clamps
1 silver set of handle bar clamps
Set of wrist pin needle bearings
Oil dipstick
TPS Controller
Back Brake resivoir cap
Little handlebar lever for Misc use.
2 Coolant overflow bottles
Rear dogbone suspension linkage for shock/swingarm mounting
Clutch Cover insert
Water pump cover
Renthal Racing Handlebar pad
Fly Racing pad cover
Steering Stems $35 for both $20 a piece
Brand New ITP Sand Star Rear Left Paddle Tire 20x11x8 L
can i give you 10 bucks (CANADIAN) for:
-renthal handlebar cover
-oil dipstick
-and the 2 stearing stems
PS: i live in Canada
You are smart like Dump Truck! :jesterlaugh:
