well i took my bike to the dunes in augest ran great for 2.5 days then it craped out slowly over the period of 2 days. well it ran fine it just had no spark. so slowly i changed the entire electrical system and changed the cdi today thanks to quick shipping by NYUK. now i got spark like alot of spark i kicked it lightly and there was lots of blue. however i got no start. its been like 4 months and im not sure if its just gonna be like that because its been so long. i put fresh gas in it 100LL and i had a little bit of 100LL left in it from before. kicked the living crap out of it got nowhere i got good compression carbs are good just no dice anyone got any tips?
pull the fuel line and see you if you getting fuel from the petcock. If so you will need to go into the carbs. Also try tap'n the sides of the bowls and see if the floats are stuck with the fuel line back on. Then try kick'n it again. If still no start then pull the plugs to see if they are getting wet. If not then your going to have to pull the carbs and clean them.
well i got clear lines and gas is going to the carbs I will check if the plugs are getting wet. the bowls may be stuck i will open them up tomorrow and give them a little freshing up.it has been 4 months
