After a couple weeks contemplating trying it out, and a few discussions on here. Finally it runs on E85!
A few mods had to take place, and if anyone would like to know i can explain.
This bike is stock other than fmf pipes.....
jetting is as follows: 40 pilots and 500 main. Got it from from vito's (thanks BTW) .It could use a 45 pilot as the air screw is only a half turn out and it likes it.
Plugs look great! A little on the fat side, but hey its cold here and it pulls through perfect.
thanks banshee HQ!
are you going by the color of the plug or the heat readings?
the color of the plug where the sun dont shine, took her out for a few more rips in top gear WOT and snd seems the off idle may be a little on the fat side.
if Ethonal works (plug reading wise) like methonal, the jetting must be waaayyyy rich. I know from 4 cyl racing i do, it may take a couple hits to make the plug change color, and im getting color in one hit. maby its the E85? who knows, it seems to be running great, i will keep you informed on how it stays....
plugs are one step colder heat range wise
i may throw it on my buddys dyno with some widebands, to see where we are at...
