rajaa11 Posted December 1, 2009 Report Share Posted December 1, 2009 (edited) Hello all, I would like to put a air box on my bike with a K&N air filter and outta wears with NO lid, I recently moved from Florida to Philly and its to wet were I ride for no air box. Bike was purchase in Florida with no air box, so I would like to know what I will LOSE and a idea where to start with my jetting. Right now I'm running dual 28mm Mikuni carbs with Tors boxes removed, K&N Pod filters(No air box)with outta wears. Pilot are 27.5 and mains are 350 with needle clip on 3rd slot and 1.5 turn on air/fuel screw. Bike is bored out to .40 over with standard stroke. V-force 3's carbon fiber reeds and adjustable timing plate set at +4, Trinity stage 4 head with 21cc domes running pump gas 93 at 40:1 and T5 pipes and silencers. Thanks Edited December 1, 2009 by rajaa11 Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted December 1, 2009 Report Share Posted December 1, 2009 Are you ported? If not 300 would be more than enough on mains with an air box and no lid. Nice picture. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 1, 2009 Report Share Posted December 1, 2009 well, are they stock 26's, bored out stock carbs, or 28's? you would usually just go down 1 size on the main, if any. get it pinned wot, mid-high rpm range, and see what it does. if it starts to sputter, then go down in size untill it can hang up at wot no sputter, then do a plug chop. you shouldn't loose power going to the box. can you snap a pic of the carbs?,,,oh and some of that sexy bitch of a bike Quote Link to comment Share on other sites More sharing options...
rajaa11 Posted December 2, 2009 Author Report Share Posted December 2, 2009 well, are they stock 26's, bored out stock carbs, or 28's? you would usually just go down 1 size on the main, if any. get it pinned wot, mid-high rpm range, and see what it does. if it starts to sputter, then go down in size untill it can hang up at wot no sputter, then do a plug chop. you shouldn't loose power going to the box. can you snap a pic of the carbs?,,,oh and some of that sexy bitch of a bike Well My carbs are from a RZ350 that come with 28's standard I think it has a MX port job, Not sure Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 2, 2009 Report Share Posted December 2, 2009 that doesn't nescicarily mean that they are 28's...unless they are bored that size all the way through......i measured 3 different stockers and they are all around 28mm..(1.105") you cansee what the fully bored carbs look like to the slide......those in the background are aftermarket bored, so they are shinier.... Quote Link to comment Share on other sites More sharing options...
rajaa11 Posted December 2, 2009 Author Report Share Posted December 2, 2009 that doesn't nescicarily mean that they are 28's...unless they are bored that size all the way through......i measured 3 different stockers and they are all around 28mm..(1.105") you cansee what the fully bored carbs look like to the slide......those in the background are aftermarket bored, so they are shinier.... you learn something new everyday, so if I put 300 in the main and leave the 27.5 pilots in I should lose no top end? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 3, 2009 Report Share Posted December 3, 2009 well, i am not saying definately that they are not 28's....like i said, you have to measure what it's at @ the bore near the slide. if it reduces there like the stockers do, then it's not 28's, but if it stays that diameter strait through, then it's 28mm....i'll get you the pic if what i'm talking about. those carbs behind the caliper are my 28's that have been bored out to a little more than 29, but you can see how it stays constant bore all the way through..........what jets are in there now. also, what were the temps and elevations where it was before and where you ride now? it is much easier to adjust to the new conditions with a good base, rather than guestimating on the setup as usuall. Quote Link to comment Share on other sites More sharing options...
